Transloadit module ...
Transloadit module - Uploading and processing files
kaidano
(@kaidano)
Hi dear makers! Struggling with building automation with Transloadit. I want this service to generate a thumbnail for uploaded video. It works perfectly through the web interface, but I lack of knowledge to make it work through callin.io.
Does anybody have this experience? Thank you!
Posted : 15/11/2023 10:10 pm
It seems you're looking to use the Video Encoding endpoints for Transloadit.
However, it appears that Transloadit doesn't offer a dedicated module for this on callin.io.
You can submit this as a suggestion to the Idea exchange, specifically under App improvement ideas. Remember to check if it's already been suggested before posting!
If the external service provides a Developer API Reference/Documentation, you should be able to integrate the endpoints within callin.io by using the general HTTP “Make a request” module.
Posted : 16/11/2023 12:32 am
