Trouble locating We...
Trouble locating Webhook Variable
Varshika_75
(@varshika_75)
I've been attempting to develop an AI voice assistant using callin.io and callin.io. However, I'm encountering an issue where a variable isn't appearing in the module.
Posted : 28/02/2025 1:14 pm
Which variable are you expecting?
Perhaps you should add a filter after the webhook so that you process the correct event “type” — when it is completed/successful.
Hope this helps! Let me know if there are any further questions or issues.
P.S.: Investing some effort into the callin.io Academy will save you lots of time and frustration using callin.io.
Posted : 01/03/2025 3:59 pm
