Trouble retrieving ...
Trouble retrieving previous values with Airtable nodes
Bluedog04
(@bluedog04)
Hello! I'm encountering an issue with undefined values from preceding nodes in my callin.io workflow. While some data passes through without problems, issues arise when I use nodes that search for records, particularly with Airtable nodes. The workflow functions correctly when processing a single item.
I've tried rearranging and connecting nodes in various ways to ensure the previous node data is handled correctly, but I'm feeling quite frustrated.
I'm unable to share my workflow due to exceeding the character limit.
Error: Multiple matching items for expression [item 0]
This error occurs in the second Airtable node, which is intended to upsert a record.
Posted : 17/01/2025 9:04 pm
Please share these details to help us understand the issue better.
Bluedog04
(@bluedog04)
For those who encounter this later, I resolved it using a loop. The callin.io documentation notes that certain nodes do not iterate through each item, requiring the use of a Loop node to process individual items. This is often the case with database nodes.
It doesn't specifically mention Airtable search or upsert nodes, however. It's possible I was misconfiguring something, but the loop node enabled everything to function correctly.
Posted : 18/01/2025 7:01 am
Posted : 18/04/2025 7:01 am
