Troubleshooting dat...
Troubleshooting data mapping issues
Jason-chen-taiwan
(@jason-chen-taiwan)
“Image url 1”: “<a href="" https://cdn.leonardo.ai/users/9764fe4a-3e44-4138-8322-93ea56448ab1/generations/98980369-asd-b608-fde178a254e2/Leonard o"LightningXLInthedistantfuturehumanshavesucces0.jpg" rel="noopener nofollow ugc"> https://cdn.leonardo.ai/users/9764fe4a-3e44-4138-8322-93ea56448ab1/generations/98980369-asd-b608-fde178a254e2/Leonardo LightningXLInthedistantfuturehumanshavesucces0.jpg”
“Image url 2”: “<a href="" https://cdn.leonardo.ai/users/9764fe4a-3e44-4138-8322-93ea56448ab1/generations/cbb89d31as91fa1d5e0a3f/Leonard o"LightningXLHowevertheminersbegantodisappearon0.jpg" rel="noopener nofollow ugc"> https://cdn.leonardo.ai/users/9764fe4a-3e44-4138-8322-93ea56448ab1/generations/cbb89d31as91fa1d5e0a3f/Leonardo LightningXLHowevertheminersbegantodisappearon0.jpg”
“Image url 3”: “<a href="" https://cdn.leonardo.ai/users/9764fe4a-3e44-4138-8322-93ea56448ab1/generations/basdfd4-9f59-386226ed4b30/Leonard o"LightningXLAdventurerJickdecidedtodelveintot0.jpg" rel="noopener nofollow ugc"> https://cdn.leonardo.ai/users/9764fe4a-3e44-4138-8322-93ea56448ab1/generations/basdfd4-9f59-386226ed4b30/Leonardo LightningXLAdventurerJickdecidedtodelveintot0.jpg”
“Image url 4”: “<a href="" https://cdn.leonardo.ai/users/9764fe4a-3e44-4138-8322-93ea56448ab1/generations/ba20asb1cf-136df17b3de4/Leonard o"LightningXLSuddenlyJickwasengulfedbyagraymis0.jpg" rel="noopener nofollow ugc"> https://cdn.leonardo.ai/users/9764fe4a-3e44-4138-8322-93ea56448ab1/generations/ba20asb1cf-136df17b3de4/Leonardo LightningXLSuddenlyJickwasengulfedbyagraymis0.jpg”
“Image url 5”: “<a href="" https://cdn.leonardo.ai/users/9764fas-8322-93ea56448ab1/generations/b1e46baa-3f98-4c03-bf49-8ae190536e37/Leonard o"LightningXLWhenhewokeuphefoundhimselfatthe0.jpg" rel="noopener nofollow ugc"> https://cdn.leonardo.ai/users/9764fas-8322-93ea56448ab1/generations/b1e46baa-3f98-4c03-bf49-8ae190536e37/Leonardo LightningXLWhenhewokeuphefoundhimselfatthe0.jpg”
“Image url 6”: “<a href="" https://cdn.leonardo.ai/users/9764fe4adas-93ea56448ab1/generations/32f4f89a-e2d4-40c6-8f65-23e6f93390c4/Leonard o"LightningXLUnawareofhowhegotoutJicklooksint0.jpg" rel="noopener nofollow ugc"> https://cdn.leonardo.ai/users/9764fe4adas-93ea56448ab1/generations/32f4f89a-e2d4-40c6-8f65-23e6f93390c4/Leonardo LightningXLUnawareofhowhegotoutJicklooksint0.jpg”
“output”:
“S1”: “In the distant future, humans have successfully moved to Mars and begun deep mining of the Randolph ore.”,
“S2”: “However, the miners began to disappear one by one, and eerie noises emanated from the mine.”,
“S3”: “Adventurer Jick decided to delve into the mines to uncover the mystery. He encountered these missing workers but found them completely devoid of human consciousness, devoted to relentlessly mining the Randolph ore.”,
“S4”: “Suddenly, Jick was engulfed by a gray mist that sprang from nowhere, and incomprehensible illusions flashed before his eyes.”,
“S5”: “When he woke up, he found himself at the top of the mine with unfamiliar tools around him, and the mine… had become infinitely deep, like an endless black hole.”,
“S6”: “Unaware of how he got out, Jick looks into the now seemingly bottomless mine, confusion and fear reflecting in his eyes.”,
“T”: “The Deep Mineshaft”,
“D”: “In the distant future, humans discover the mystical Randolph ore on Mars. However, those delving deep into it start disappearing. What’s going on? #SciFi #MarsExploration #RandolphOre
my merge output is this one.
But when i use
“template_id”: “1b945644ad785”,
“modifications”:
“Image-1.source”: “{{ $json[‘Image url 1’] }}”,
“Voiceover-1.source”: “{{ $json.output.S1 }}”,
“Image-2.source”: “{{ $json[‘Image url 2’] }}”,
“Voiceover-2.source”: “{{ $json.output.S2 }}”,
“Image-3.source”: “{{ $json[‘Image url 3’] }}”,
“Voiceover-3.source”: “{{ $json.output.S3 }}”,
“Image-4.source”: “{{ $json[‘Image url 4’] }}”,
“Voiceover-4.source”: “{{ $json.output.S4 }}”,
“Image-5.source”: “{{ $json[‘Image url 5’] }}”,
“Voiceover-5.source”: “{{ $json.output.S5 }}”,
“Image-6.source”: “{{ $json[‘Image url 6’] }}”,
“Voiceover-6.source”: “{{ $json.output.S6 }}”
The output always undefined. But i use the mouse to grab the data to parameter. I don’t know why.
To Reproduce
like this merge and post
Expected behavior
i think the parameter should mapping right
Operating System
windows
callin.io Version
callin.io@1.86.1
Node.js Version
v22.13.0
Database
SQLite (default)
Execution mode
main (default)
Posted : 10/04/2025 12:32 pm
mdmiko
(@mdmiko)
It looks like your post has some formatting issues...
Posted : 10/04/2025 12:43 pm
Jason-chen-taiwan
I utilized drag-and-drop to populate the parameters, but it continues to display as undefined. I'm unsure of the reason.
Posted : 10/04/2025 1:08 pm
mdmiko
(@mdmiko)
Could you share a screenshot or code snippet using the < > button?
Try configuring a Set node and mapping every single field.
Also, include a generic field like {{ $json.toJsonString() }}.
This might help in understanding the contents of the node's reply.
Posted : 10/04/2025 2:33 pm
Posted : 09/07/2025 2:34 pm
