TypeError: Cannot r...
TypeError: Cannot read properties of undefined (reading 'content') - Troubleshooting Help
NadamHL
(@nadamhl)
Stack trace
TypeError: Cannot read properties of undefined (reading 'content') at ToolCallingAgentOutputParser._baseMessageToString (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/output_parsers/base.cjs:24:31) at ToolCallingAgentOutputParser._callWithConfig (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/output_parsers/base.cjs:49:32) at ToolCallingAgentOutputParser._callWithConfig (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/runnables/base.cjs:223:34) at processTicksAndRejections (node:internal/process/task_queues:95:5) at ToolCallingAgentOutputParser._streamIterator (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/runnables/base.cjs:165:9) at ToolCallingAgentOutputParser.transform (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/runnables/base.cjs:402:9) at RunnableSequence._streamIterator (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/runnables/base.cjs:1320:30) at RunnableSequence.transform (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/runnables/base.cjs:402:9) at wrapInputForTracing (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/runnables/base.cjs:275:30) at pipeGeneratorWithSetup (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/utils/stream.cjs:271:19) at RunnableLambda._transformStreamWithConfig (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/runnables/base.cjs:296:26) at wrapInputForTracing (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/runnables/base.cjs:275:30) at pipeGeneratorWithSetup (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/utils/stream.cjs:271:19) at RunnableLambda._transformStreamWithConfig (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/runnables/base.cjs:296:26) at RunnableSequence._streamIterator (/usr/local/lib/node_modules/callin.io/node_modules/@langchain/core/dist/runnables/base.cjs:1320:30)
  • callin.io version: 1.91.2
  • Database (default: SQLite): sqlite
  • callin.io EXECUTIONS_PROCESS setting (default: own, main): main
  • Running callin.io via (Docker, npm, callin.io cloud, desktop app): docker
  • Operating system: centos 7.9
Posted : 07/05/2025 1:52 am
NadamHL
(@nadamhl)
I attempted to create a custom agent for a chat model, and this agent interacted with the custom agent, which in turn accessed either OpenAI's or Deepseek's chat model indirectly. The data formats returned from both the custom proxy and direct access to the chat model appear normal, but the content field is consistently empty. Below is the data returned by our access interface /v1/chat/completions:
"id": "943b2464-b3e4-49a6-a69c-dafdafa23e2",
"object": "chat.completion",
"created": 1746524189,
"model": "deepseek-chat",
"choices": [
"index": 0,
"message": {
"role": "assistant",
"content": "",
"tool_calls": [
"index": 0,
"id": "call_0_1c581ecb-a6a1-4d70-870a-dasfdasfa",
"type": "function",
"function": {
"name": "ai_security_knowledge_base_tool",
"arguments": "{"input":"[0000-0000]重点业务错误码100001的处理步骤"}"
"logprobs": null,
"finish_reason": "tool_calls"
"usage": {
"prompt_tokens": 520,
"completion_tokens": 41,
"total_tokens": 561,
"prompt_tokens_details": {
"cached_tokens": 512
"prompt_cache_hit_tokens": 512,
"prompt_cache_miss_tokens": 8
"system_fingerprint": "fp_8802369eaa_prod0425fp8"
Posted : 07/05/2025 1:57 am
NadamHL
(@nadamhl)
This is the primary logic for our proxy service implementation, designed to receive a response from Deepseek and relay it directly to the aiagent.
// Forwarding to Deepseek
func forwardToDeepseek(w http.ResponseWriter, req APIRequest) {
    body, err := json.Marshal(req)
    if err != nil {
        sendError(w, http.StatusInternalServerError, "Failed to marshal request")
        return
    httpReq, _ := http.NewRequest("POST", "https://api.deepseek.com/v1/chat/completions", bytes.NewReader(body))
    httpReq.Header.Set("Authorization", "Bearer "+"sk-12312312dassdw123123")
    httpReq.Header.Set("Content-Type", "application/json")
    httpReq.Header.Set("Accept", "application/json")
    client := &http.Client{Timeout: 30 * time.Second}
    resp, err := client.Do(httpReq)
    if err != nil {
        sendError(w, http.StatusBadGateway, "OpenAI service error")
        return
    defer resp.Body.Close()
    t, _ := ioutil.ReadAll(resp.Body)
    // Returning the string
    fmt.Fprintf(w, string(t))
Posted : 07/05/2025 2:03 am
For_Gm
(@for_gm)
I'm experiencing the same.
Do you have a contract?
Posted : 02/06/2025 3:36 pm
