Unsure How to Extra...
Unsure How to Extract Data from an Array
JimmyJ9000
(@jimmyj9000)
I'm new to this platform and I'm attempting to connect a module from an AI time-tracking application called Timely, which has a callin.io module, to an Airtable base I've set up.
I'm trying to determine how to extract data from an array that I believe contains one or two text strings I want to isolate and place into a specific Airtable field.
Should I use the iterator for this purpose? For instance, would the sequence be: Timely App -> Iterator -> Airtable module?
Screen Shot 2023-03-25 at 11.48.41 AM
Screen Shot 2023-03-25 at 11.48.34 AM
This is what I've done, essentially placing the array data into the Iterator module –
But I'm unsure of the next steps to retrieve that data. Can anyone offer some assistance?
When asking your question, please include:
:footprints: The steps you have taken
:camera_flash: Relevant screenshots
:link: Any links you have
[ Code { "and": "JSON", "in" : "code block"} ]
:x: Exclude Personal Information.
Posted : 25/03/2023 3:59 pm
Wemakefuture
(@wemakefuture)
Hi. First, utilize an iterate module and map the array using the map function.
Thanks, Helio!
callin.io
If you have questions, feel free to reach out.
:wink:
Posted : 26/03/2023 11:24 am
JimmyJ9000
(@jimmyj9000)
Thanks for the response! So are you suggesting:
Timely > Iterator > Set Variable/Map Array > Airtable
or
Timely > Set Variable/Map Array > Iterator > Airtable?
Thanks a lot!
Posted : 26/03/2023 1:35 pm
Wemakefuture
(@wemakefuture)
You need to map the precise array you require. If iteration is necessary after Timely, allow it and map it following that iteration.
Thanks!
:wink:
Posted : 27/03/2023 11:25 am
JimmyJ9000
(@jimmyj9000)
I apologize, but I'm still unclear on your request. I'm attempting to map an array, but my goal is to extract specific data from within that array and direct it to its intended destination.
Posted : 27/03/2023 12:17 pm
