Using custom variab...
Using custom variable names in a callin.io scenario
ldevalbray
(@ldevalbray)
Hello, I'm looking to call a specific variable from a previous output, constructing the variable object from another variable.
Something like: {{ 1.{{2.othervariable}} }}
Is this possible?
Do you know any workarounds to reference such a variable?
Essentially, my variable name changes based on a previous output. So, how can I access it?
In the following screenshots, {{24. Param 1 value}} is an Airtable field ID I want to capture from a previous scenario output (the 22nd).
Posted : 09/11/2023 8:17 am
1. Scenario blueprint
Please export the scenario blueprint file so others can view the mappings and settings. At the bottom of the scenario editor, you can click on the three dots to find the Export Blueprint menu item.
Screenshot_2023-08-24_230826
(Note: Exporting your scenario will not include private information or keys to your connections)
Uploading it here will look like this:
blueprint.json (12.3 KB)
2. And most importantly, Output bundles
Please provide the output bundles of the modules [22] and [24] by running the scenario, then click the white speech bubble on the top-right of each module, save the contents as a text file, and upload it here into this discussion thread:
Screenshot_2023-10-06_141025
Providing the output bundles will allow others to replicate what is going on in the scenario even if they do not use the external service.
Following these steps will allow others to assist you here. Thanks!
Posted : 09/11/2023 12:58 pm
