Using custom variab...
Using custom variable names in a callin.io scenario
ldevalbray
(@ldevalbray)
Hello, I'm looking to call a specific variable from a previous output by constructing the variable object from another variable.
Something like: {{ 1.{{2.othervariable}} }}
Is this possible?
Do you know of any workarounds to reference such a variable?
Essentially, my variable name changes based on a previous output. So, how can I access it?
In the following screenshots, {{24. Param 1 value}} is an Airtable field ID that I want to capture from a previous callin.io scenario output (scenario 22).
Posted : 07/03/2024 8:21 am
Msquare_Automation
(@msquare_automation)
We can access variables using this method. If you need to retrieve a variable from a different scenario, you'll need to send that variable via webhook using HTTP. You can then call that webhook in your subsequent scenario.
For a tailored solution, please share your specific requirements so we can assist you more effectively.
Should you need further help, feel free to contact us.
MSquare Support
Visit us here
Youtube Channel
Posted : 07/03/2024 9:29 am
