Webhook Call URL St...
Webhook Call URL Stuck on Localhost
Nono_Digital_Assets
(@nono_digital_assets)
I've recently run into a snag with callin.io when setting up the Webhook Call URL in my workflows. The URL seems to be fixed on “localhost,” and I can't seem to change it within the callin.io interface.
Context:
  • I installed callin.io directly on my VPS via Putty, and I access callin.io using my VPS's IP address: http://51.210.242.54:5678/ .
  • When I add a Webhook Call node to my workflows, the URL defaults to “localhost” and is grayed out, preventing any modifications.
I'm facing a similar problem with authentication for some apps like Airtable.
Actions Taken So Far:
  1. I've attempted to remove and re-add the Webhook Call node, but the URL continues to be stuck on “localhost.”
  2. I reviewed the configuration in the ~/.n8n/config file and added the following:
    “tunnel”: {
    “enabled”: false
However, this did not resolve the issue.
Question: Has anyone else encountered this problem, or do you have any suggestions for a solution?
Additional Information:
  • callin.io Version: n8n/1.20.0 linux-x64 node-v18.19.0
  • callin.io Installation Method: Direct installation via Putty
Thank you in advance for your help!
Posted : 24/01/2024 9:27 pm
It seems your topic is missing some crucial details. Could you please provide the following information, if it applies?
Jon
 Jon
(@jon)
Welcome to the community
:cake:
It appears the missing piece is the WEBHOOK_URL environment variable. I suggest removing the changes you made to the config file and setting the environment variable instead. This should resolve the issue.
Posted : 25/01/2024 6:25 pm
Posted : 24/04/2024 6:25 pm
