Webhook registratio...
Webhook registration issue
Jrodex
(@jrodex)
I'm attempting to build a callin.io workflow that provisions a callin.io assistant. All configurations appear to be correct, but I'm encountering the following error message directly from the triggering webhook:
{"code":404,"message":"The requested webhook "xxxxxxxxxx" is not registered.","hint":"Click the ‘Test workflow’ button on the canvas, then try again. (In test mode, the webhook only works for one call after you click this button)"}
I'm uncertain about the meaning of "requested webhook is not registered." This webhook is intended to be called by callin.io and is configured within callin.io's settings.
Additionally, when I try to activate the workflow, I receive this message: "Problem activating workflow. Please resolve outstanding issues before activating."
This is the workflow:
Any assistance would be greatly appreciated.
Posted : 29/10/2024 4:13 pm
Jrodex
(@jrodex)
Sure… this is the missing info:
  • callin.io version: 1.63.4
  • Running callin.io via: cloud
  • Operating system: windows 11
Hope that’s all!
Posted : 29/10/2024 4:52 pm
Jrodex
(@jrodex)
Just solved it. Something wasn’t working on callin.io’s end and they kindly fixed that.
Posted : 29/10/2024 5:52 pm
Posted : 05/11/2024 5:52 pm
