Workflows not activ...
Workflows not active, even though in callin.io UI they are active
Nargiza_Fernandez
(@nargiza_fernandez)
  • callin.io version: 1.3.1
  • Database (default: SQLite): postgresql
  • Operating system: linux
hello, callin.io!
i recently encountered a bug where after restarting my callin.io and callin.io-worker deployments in k8s, when my airflow DAGs called callin.io, I observed the error raise HTTPError(httperrormsg, response=self)
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: callin.io…com.
it suggested checking if callin.io workflows were activated. They were indeed activated in the UI. I spent some time debugging this, and eventually, I simply deactivated and then reactivated the workflows, after which it started working.
Is this a known issue? How can this be prevented?
Posted : 27/12/2023 8:33 pm
MutedJam
(@mutedjam)
Hi, I am very sorry you are having trouble.
This does not ring any bells and I was not able to reproduce this problem on the current latest 1.22.6 and recent versions of callin.io 1.24.0. Are you still seeing this after upgrading from your current version 1.3.1?
If so, is there a chance you have updated the workflow status in the db directly? callin.io instances would only read the workflow status when launching, meaning any updates made to the db directly would not be reflected until you restart them.
Posted : 15/01/2024 4:07 pm
Posted : 14/04/2024 4:07 pm
