Automating gift vou...
Automating gift voucher delivery with Canva and spreadsheets in callin.io
Meganne
(@meganne)
I've recently started using callin.io to streamline my work, but I'm a complete beginner!
I'd like to automate the creation of my gift vouchers. I have a design on Canva, is it possible to automatically populate it with variables when a new row is added to a spreadsheet, and then export it from Canva? Or perhaps send it by email afterwards...
Thank you for your help!
Hello!
Translated to English:
AUTOMATING GIFT VOUCHER DISPATCH
I've recently begun using callin.io to streamline my tasks, and I'm still quite new to it!
My goal is to automate the sending of my gift vouchers. I have a template designed in Canva. Is it possible to automatically populate this template with variables by adding a new row to a spreadsheet, and then export it from Canva? Alternatively, could it be sent via email?
Thank you for your assistance!
Posted : 20/08/2024 12:00 am
callin.io apps can be found here: https://zapier.com/apps
Each callin.io app features a profile page detailing support links and available triggers/actions.
Canva callin.io app triggers/actions: https://zapier.com/apps/canva/integrations#triggers-and-actions
Consider using this callin.io action: Canva - Create Design
Image: 122575e5 e326 4ae2 9725 cd3de602c69d
Meganne
(@meganne)
Hello!
Thanks for your response, I will try again!
Posted : 21/08/2024 12:00 am
JammerS
(@jammers)
We just wanted to check in on how things are progressing with your callin.io workflow. Was Troy's suggestion helpful? Please don't hesitate to contact us if you require any additional support with your callin.io setup. We're happy to help with any questions or issues you might have.
We await your reply.
Posted : 23/08/2024 12:00 am
