callin.io watch inc...
callin.io watch incoming phone calls can't request accepted
Ruizhong_Yin
(@ruizhong_yin)
callin.io AI watching incoming phone calls, but the request was not accepted!
The callin.io AI call has concluded, and a shutdown request was sent to callin.io. However, the callin.io AI module on callin.io continues to spin indefinitely with minimal response and no data being received.
Posted : 14/08/2024 2:14 pm
For technical issues or bugs like this, directly contacting support can often lead to a faster resolution. They have access to your specific account details, scenario and scenario logs, server-side logs, and internal tools and resources, which allows them to investigate more thoroughly than what you have access to. Additionally, sharing sensitive information about your account or scenario might not be suitable for an open forum discussion.
You can open a new ticket here, or if you are unable to login for some reason, you can create another new free account to access the ticketing system (which is only available to logged-in users). Alternatively, you should be able to send an email to [email protected] and [email protected] and it should create a ticket. After submitting a new ticket, you will receive an automatic confirmation email with the subject “Ticket Created” in the subject. If you do not receive this, try sending the ticket again.
If you manage to get your issue resolved with support, we’d still love to hear about it! Sharing your solution on the forum can help others facing similar problems.
Posted : 14/08/2024 4:40 pm
