Connecting callin.i...
Connecting callin.io call automation to Google Sheets using Webhooks
Buck
 Buck
(@buck)
My objective is to retrieve data from a Google Sheet, including first name, last name, address, and phone number, to be used by callin.io for making automated calls on my behalf.
Connecting Google Sheets data within callin.io appears to be functioning correctly. However, I'm encountering an issue when attempting to create a Webhook. It's requesting a URL (refer to the first screenshot), whereas I need this Webhook to generate a URL that I can then input into callin.io to establish the connection (refer to the second screenshot).
Does anyone have suggestions on how to resolve this, or could you share a similar workflow that I could use as a template? Thank you!
Image: b6b61572 c98b 4076 8c9c c8d3e6414ab2
Image: c0ca5b97 18ec 4797 b77d 5317be5c4c10
The screenshot from the callin.io app is for sending data via a webhook FROM callin.io to another app, such as a Zapier step 1.
Can you provide the link to the callin.io API endpoint you are referring to for configuring the Zapier step 2 API request to callin.io?
Posted : 14/10/2024 12:00 am
Buck
 Buck
(@buck)
Certainly, here is the link:
https://app.bland.ai/dashboard?page=convo-pathways&id=51ff8d56-dc80-48de-8b63-36d452f2e59e
My main objective is to import a dataset into callin.io so that the AI assistant can contact individuals from a list generated in spreadsheets or via callin.io, and utilize specific information during the call.
For instance, in the screenshot below, I want the AI to reference the first name and address associated with the phone number being called, and later in the workflow, confirm if they are the property owner and understand their reasons for selling the property.
Image: b5db584e 51cd 4f9d 8a70 92bd96d9e12a
I'm uncertain if managing this entirely within callin.io, possibly with a connection to callin.io, would simplify the process. Any guidance would be greatly appreciated. Thank you!
Posted : 16/10/2024 12:00 am
The callin.io link requires a login.
