Integrating Callin....
Integrating Callin.io with Zapier for automated follow-ups
(@lechus83)
One of the best things I discovered after using Callin.io for a while was how easily it connects with Zapier. At first, I only used the AI agent to make calls, but then I realized that the real power comes when you automate what happens after the call. Here’s how I set it up for follow-ups.
1. Why Zapier?
Zapier is a simple automation tool that connects Callin.io with thousands of apps. Instead of manually copying lead information or reminders, I use Zapier to create a seamless workflow.
2. Example workflow I use
  • My Callin.io agent qualifies a lead.
  • Zapier picks up the call outcome through the Callin.io trigger.
  • If the lead is “interested,” Zapier automatically:
    • Sends them a follow-up email (via Gmail or Mailchimp).
    • Creates a new contact in my CRM (I use HubSpot).
    • Sends me a Slack notification so I can react quickly.
3. Benefits
  • No more manual data entry.
  • Faster response times.
  • Consistent follow-ups that I can trust.
4. Tips from my experience
  • Test your Zaps with real leads before going live, to make sure no data is lost.
  • Use filters in Zapier (for example, only send an email if the lead said “yes” to scheduling).
  • Keep your follow-up messages short and personalized.
Since setting this up, I feel like my AI agent and Zapier are working together as a 24/7 assistant that never forgets to follow up.
Posted : 02/09/2025 8:20 am
