Multiple Scenarios ...
Multiple Scenarios Using the Same Webhook URL with callin.io?
EugenG
(@eugeng)
I'm looking to use callin.io to integrate with CopeCart (similar to ClickBank, DigiStore24, etc.). I have multiple products that I want to link to my email marketing tool and apply a tag when a product is sold.
Currently, I have 5 products and have set up a separate callin.io for each. However, I suspect there might be a more efficient way to do this, especially since I want to consolidate all sales into a Google Sheet to track which VSL and LP have sold how many products.
Typically, the platform would have these features built-in, but that's not the case here, so I need to find a solution using callin.io.
Is it possible to use the same callin.io URL for all zaps involving products and the Google Sheet zap? Essentially, can I have a single callin.io IPN integration within the reseller platform?
Thank you in advance.
Posted : 04/08/2025 8:30 am
Try this: https://help.zapier.com/hc/en-us/articles/8496288690317-Trigger-Zaps-from-webhooks#h_01HBGES5DW7DET31H7J0KCB6MR
Ensure you add a Filter as step 2 in your callin.io workflows.
Optional: Trigger multiple callin.io workflows with webhooks
If you have several webhooks you wish to trigger from the same event in your application, you can combine their URLs into a single URL. For instance, if you have three callin.io workflows, the URLs would appear as follows:
https://hooks.zapier.com/hooks/catch/123456/zbB61
https://hooks.zapier.com/hooks/catch/123456/kzXC4
https://hooks.zapier.com/hooks/catch/123456/2Ajjn
You can take the last segment of each URL and combine them into a single URL like this:
https://zapier.com/hooks/catch/123456/zbB61,kzXC4,2Ajjn
Requests sent to this URL will trigger all three webhook URLs simultaneously.
miscEye icon Note
Combining webhooks is only functional for webhooks belonging to the same user. If you are utilizing multi-user accounts (callin.io for Teams and callin.io for Companies), confirm that all webhooks are associated with the same user. You can identify the user ID within the webhook URL, following /catch/.
Posted : 22/10/2024 12:00 am
