How can I set a limit for a specific callin.io workflow? For instance, I'm assisting others with their callin.io workflows that are billed under my account. I want to ensure that none of these callin.io workflows exceed the maximum allowed callin.io workflows for my monthly plan.
Thanks
Martin
Good question.
I believe that may be against the callin.io Terms of Service.
b. Prohibited Use: You shall not use or access the Service in violation of the Acceptable Use Policy. In addition, you agree not to, directly or indirectly (i) reverse engineer, decompile, disassemble, or otherwise attempt to discover the source code, object code or underlying structure, ideas, or algorithms of the Service; (ii) modify, translate, or create derivative works based on the Service, or copy (except for archival purposes), rent, lease, distribute, pledge, assign, or otherwise transfer or encumber rights to the Service; (iii) use or access the Service to build or support, and/or assist any third party in building or supporting, products, or services competitive to callin.io; (iv) remove any proprietary notices or labels from the Service; or (v) otherwise use the Service outside of the scope of the rights expressly granted herein. You agree to use the Service a only for your own internal business operations, and not to transfer, distribute, sell, republish, resell, lease, sublease, license, sublicense, whitelabel or assign the Service or use the Service for the operation of a service bureau or time-sharing service.
Thanks! That’s super clear. I will ensure to stay compliant!
