AI Agent Error: Too...
AI Agent Error: Tool Input Schema Mismatch on Complex Call
xtreme137
(@xtreme137)
Topic Title: AI Agent Fails with "Received tool input did not match expected schema" on Complex Tool Call
* Your callin.io Version: 1.103.2 (Cloud)
* The Error: Received tool input did not match expected schema
* Summary of the Problem:
“The AI Agent fails to call a Code node tool that uses multiple parameters (including some of type JSON). The error occurs even when the prompt provides a direct command with hardcoded data that perfectly matches the tool’s schema. Simple, no-argument tools work, but the agent fails when it needs to construct the arguments for a more complex tool.”
`json
“nodes”: [
“parameters”: {
“chatModel”: “openai:gpt-4o”,
“prompt”: {
“__rl”: true,
“value”: “Your only task is to call the
formatemailhtml tool. You must use these exact, hardcoded values for the parameters:n- weatherData : { "conditions": "test weather", "temperature": 75 }n- todaysEvents : [{ "name": "Test a meeting" }]n- upcomingEvents : <span class="chcklst-box fa fa-square-o fa-fw"></span>n- recommendation : "This is a test of the formatting tool.",
“mode”: “define”
“name”: “AI Agent”,
“type”: “callin.io/n8n-nodes-langchain.agent”,
“typeVersion”: 2.1,
“position”: [
1120,
360
“credentials”: {
“openAiApi”: {
“id”: “YOUR_CREDENTIAL_ID”,
“name”: “Your OpenAI Credential”
“parameters”: {
“toolName”: “format_email_html”,
“toolDescription”: “Formats the final email. It requires four parameters:
weatherData (object), todaysEvents (array), upcomingEvents (array), and recommendation (string).”,
“specifySchema”: true,
“schemaType”: “fixed”,
“parameters”: {
“parameters”: [
“name”: “weatherData”,
“type”: “json”,
“required”: true
“name”: “todaysEvents”,
“type”: “json”,
“required”: true
“name”: “upcomingEvents”,
“type”: “json”,
“required”: true
“name”: “recommendation”,
“type”: “string”,
“required”: true
“code”: “const weatherDataInput = weatherData || {};nconst todaysEventsInput = todaysEvents || <span class="chcklst-box fa fa-square-o fa-fw"></span>;nconst upcomingEventsInput = upcomingEvents || <span class="chcklst-box fa fa-square-o fa-fw"></span>;nconst recommendationInput = recommendation || ‘No specific recommendation provided.’;nnconst htmlEmailBody =
Test Report
Weather
${weatherDataInput.conditions || 'N/A'}
Today's Events
${todaysEventsInput.length > 0 ? todaysEventsInput[0].name : 'N/A'}
Recommendation
${recommendationInput}
``;nnreturn { string: htmlEmailBody };”
“name”: “formatemailhtml”,
“type”: “callin.io-nodes-base.code”,
“typeVersion”: 2,
“position”: [
900,
360
“connections”: {
“formatemailhtml”: {
“main”: [
“node”: “AI Agent”,
“type”: “main”,
“index”: 0
Posted : 29/07/2025 12:14 am
jabbson
(@jabbson)
Hello! Hope you're doing well. Welcome.
What steps are needed for the given workflow to cause it to fail?
Posted : 29/07/2025 12:17 am
xtreme137
(@xtreme137)
Thanks for the response. This is my initial attempt at building something, and I was working with Gemini Pro until it indicated it could no longer assist. The plan is straightforward: a daily trigger, retrieve today's calendar events, the next five days' calendar events, the weather for my town, and the air quality index (Utah experiences inversions). Finally, output a well-formatted email. Here's the AI prompt, simplified to focus on the core task: Your sole responsibility is to invoke the format_email_html tool. You must use these precise, hardcoded values for the parameters:
  • weatherData: { “conditions”: “test weather”, “temperature”: 75 }
  • todaysEvents: [ { “name”: “Test a meeting” } ]
  • upcomingEvents:
  • recommendation: “This is a test of the formatting tool.”.
Here is the email formatting that fails to align with the schema: // These variables are now passed directly as named parameters from the agent.
const todaysEventsInput = todaysEvents || ;
const upcomingEventsInput = upcomingEvents || ;
// Function to format event details
const formatEvent = (event) => {
const name = event.name || ‘N/A’;
const date = event.date || ‘N/A’;
const timeStart = event.timeStart || ‘’;
const timeEnd = event.timeEnd ? to ${event.timeEnd} : ‘’;
const platform = event.platform ? (${event.platform}) : ‘’;
return <li><strong>${name}</strong><br>When: ${date} ${timeStart}${timeEnd}${platform}</li>;
// Build the HTML for today’s events
let todaysEventsHtml = ‘’;
if (todaysEventsInput.length > 0) {
todaysEventsHtml = todaysEventsInput.map(formatEvent).join(‘’);
} else {
  • No events scheduled for today.
    // Build the HTML for upcoming events
    let upcomingEventsHtml = ‘’;
    if (upcomingEventsInput.length > 0) {
    upcomingEventsHtml = upcomingEventsInput.map(formatEvent).join(‘’);
    } else {
  • No upcoming events in the next 5 days.
    // Construct the full HTML string
        body { font-family: Arial, sans-serif; line-height: 1.6; color: #333333; margin: 0; padding: 0; background-color: #f4f4f4; }
        .email-container { max-width: 600px; margin: 20px auto; padding: 20px; border: 1px solid #dddddd; border-radius: 8px; background-color: #ffffff; }
        h2 { color: #2c3e50; margin-top: 0; }
        h3 { color: #34495e; border-bottom: 1px solid #eeeeee; padding-bottom: 10px; }
        ul { list-style-type: none; padding: 0; }
        ul li { background-color: #f8f9fa; margin-bottom: 10px; padding: 10px; border-left: 3px solid #3498db; }
        .recommendation { background-color: #ecf0f1; padding: 15px; border-left: 5px solid #1abc9c; margin-top: 20px; border-radius: 4px; }
        .footer { margin-top: 30px; font-size: 0.9em; text-align: center; color: #7f8c8d; }
    Your Daily Update
    Weather & Air Quality
    • Weather: ${weatherDataInput.conditions || 'N/A'} at ${weatherDataInput.temperature || 'N/A'}°F (feels like ${weatherDataInput.feelsLike || 'N/A'}°F)
    • Air Quality: ${(weatherDataInput.airQuality && weatherDataInput.airQuality.status) || 'N/A'} (AQI: ${(weatherDataInput.airQuality && weatherDataInput.airQuality.ozone) || 'N/A'})
    Today's Events
      ${todaysEventsHtml}
    Upcoming Events
      ${upcomingEventsHtml}
    💡 Recommendation
    // Return the final HTML in the correct object format for the agent
    Let me know if you need further assistance!
    Thanks.
    Posted : 29/07/2025 5:38 pm
