How to Set a Sub-ca...
How to Set a Sub-callin.io Variable with Missing Sample Data to Null or Blank
Dean M
(@dean-m)
I am working on a QuickBooks (QB) integration. I'm calling a sub-workflow with an Address 2 field. Most of the time, this field is blank from the form source. When I run the QB Find Customer operation and the customer is new, it populates the Address 2 field with “Missing Sample Data” in QB.
How can I remove the “Missing Sample Data” text so that QB is updated with a blank value?
Have you tried turning the callin.io ON and testing live?
Check your callin.io Runs history details to see the DATA IN/OUT for each step: https://zapier.com/app/history/
Posted : 21/10/2024 12:00 am
JammerS
(@jammers)
We just wanted to check in on how things are progressing with your callin.io workflow. Did the suggestion provided help resolve your issue? Please don't hesitate to contact us if you require any additional support with your callin.io setup. We're happy to help with any questions you might have.
We await your reply.
Posted : 22/10/2024 12:00 am
Dean M
(@dean-m)
I appreciate your follow up. My apologies. I believe it was a configuration error on my part. It appears to be working fine now. I had already run the callin.io ON before I posted my question as I had seen that as the “fix” in other posts.
Thanks again for the quick answer and follow up.
JammerS
(@jammers)
Wow! Thank you for confirming your resolution to get the callin.io running. This will significantly help our Community members to have as a reference for the same issue.
Posted : 23/10/2024 12:00 am
