Improving system pr...
Improving system prompts and workflows
Umar_Farooq
(@umar_farooq)
Agent Not Functioning Correctly with User Prompt: Skipping Tool Call for 'Get Ticket' Tool
My System Prompt:
You are an AI assistant for project management within a software company. Your primary function is to comprehend user queries and execute the appropriate tools in the correct sequence based on the user's intent.
:wrench:
Tools Available:
  • Get_Projects – Retrieves all projects and returns their IDs.
  • Get_Tickets – Use this tool exclusively when the user inquires about:
    • issues
    • tasks
    • tickets
Instructions for Get_Projects:
When the user requests only project details, always execute Get_Projects and return the project ID and name.
Instructions for Get_Tickets:
When the user asks about issues or tickets, first execute the GetProjects tool. Then, using the ID returned by GetProjects, execute the Get_Tickets tool to retrieve issue details. Return the issue IDs (top listed) and names (top listed).
From the Get_Tickets JSON response, extract and return only:
  • id (top listed)
  • name (top listed)
Please Share Your Workflow
Information on Your callin.io Setup
Posted : 25/06/2025 7:04 pm
jabbson
(@jabbson)
Would you like to elaborate on your question? What are the user inputs? Could you embed your workflow, instead of pasting a screenshot? alt text
Posted : 25/06/2025 10:31 pm
Umar_Farooq
(@umar_farooq)
The user can provide three types of inputs. They might request a list of projects, a specific project with its tickets, or initiate ticket creation. The issue arises when the agent misses the correct tool; for instance, when the user asks for a specific project and its tickets, the agent only runs the 'get project' tool.
Posted : 26/06/2025 6:10 am
jabbson
(@jabbson)
It sounds like you'll need to refine your prompt to more clearly outline the desired actions in a structured, algorithmic manner. The prompt is key to achieving the desired outcome.
Posted : 26/06/2025 2:22 pm
Umar_Farooq
(@umar_farooq)
Which model performs best for a workflow like this? Please guide me if you have any insights.
Posted : 26/06/2025 2:57 pm
jabbson
(@jabbson)
I seldom use anything besides OpenAI, which serves my needs about 99% of the time. I also appreciate their pre-paid billing model, especially when contrasted with options like Gemini.
Posted : 26/06/2025 3:06 pm
