Optimizing Automati...
Optimizing Automation: Streamlining Execution and Reducing Operation Count
ManishMandot
(@manishmandot)
Introduction:
In this post, I will address a common challenge encountered when running automation workflows that handle thousands of data points, all of which consume a significant number of operations through standard methods.
Problem:
When executing automation workflows with a large dataset or numerous rows of data, the required operation count can rapidly become overwhelming. This not only results in slower processing but also elevates the risk of encountering errors or exceeding API rate limits.
Consequently, identifying a method to minimize the operation count is essential for efficient and error-free execution.
Solution Approach:
To address this issue, we have developed an integration designed to reduce the number of operations throughout the workflow.
Our strategy involves utilizing various techniques, modules, and API calls to optimize the execution flow and streamline data management.
Actual Execution:
Our client has over 5000 lines of data stored within the ClickUp system. Their requirement is to monitor Time Entries and transfer this information to a Google Sheets document, including User Name, Job ID, start and end time, duration between start and end time, task name, list name, and more. Following the conventional procedure would necessitate performing operations equivalent to the number of data lines present in the ClickUp system.
The integration we developed comprises multiple components, including modules, API calls, and the implementation of specific formulas.
Add a heading (1)
These components collaborate to effectively process the large dataset, ensuring efficient and accurate execution. By carefully managing operations, we can significantly reduce the overall processing time.
Step 1:- The use of a Text Aggregator to consolidate data from various system modules such as ClickUp, Email, HubSpot, Zoho CRM, etc.
Step 2:- Create an aggregated text by summing values using mappable parameters, such as “value”, while employing various formulas to calculate time differences and start and end times.
The formula offers an advantage by enabling the calculation of time in HH:mm format using only minutes.
Step 3:- To address this challenge, we can utilize a module called “Make an API call” within Google Sheets. This module allows us to execute specific API calls to the desired endpoint, enabling us to leverage batch update functionality. To utilize this feature, we need to provide the spreadsheet ID and specify the data range for the batch update.
Step 4:- We created a body structure that facilitates mapping aggregated values into Google Sheets.
The specific body field includes the desired range and value to be populated in the designated sheet, along with the sheet name and range details.
Scenario Image:
Benefits:
⦁ Improved execution speed of the automation workflow
⦁ Faster completion times
⦁ Increased productivity
⦁ Reduced operation count
⦁ Minimized risk of encountering API limitations
⦁ Smoother data flow
⦁ Fewer disruptions
⦁ Effective time management
⦁ Efficient resource allocation
Conclusion:
In summary, our solution addresses the challenges encountered when running automation workflows involving a large volume of data that consume a high number of operations through standard methods.
By creating an integration that optimizes the execution flow and reduces the operation count, we enable faster execution, smoother data processing, and improved time management. Our solution not only enhances efficiency but also mitigates the risk of encountering errors or API limitations.
With these benefits in mind, our approach offers a valuable solution for optimizing large-scale automation workflows.
Posted : 02/06/2023 6:59 pm
Michaela
(@michaela)
Hello!
It's true that when we start working with larger data in callin.io, it’s crucial to be mindful of our operations and learn how to build smart scenarios.
:nerd_face:
Your tips are really appreciated! Thanks so much for sharing your insights with all of us.
Keep up the great work!
:clap:
Posted : 05/06/2023 7:53 am
